Results 1 to 11 of 11
Thread: power steering pump leaking, rebuild question
  1. #1
    Senior Member Rob's Avatar
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    I have a power steering fluid leak and i thought that it was just the pressure pipe on the steering box side. after having a look underneath i have noticed that the entire PS pump is covered in oil. It seems to be worst at the bottom near the return pipe. As i am fitting the hydraulic winch i thought that this should be sorted at the same time.
    I have 2 options, rebuild the pump myself with a Toyota gasket kit or get a used replacement that isn't leaking. A new one sounds like its going to be pricey according to ToyoDIY. Has anyone rebuilt the PS pump? If so is this a difficult job?
  2. #2
    Re: power steering pump leaking, rebuild question
    Yep easy job, hardest part is getting the drive gear off the shaft. Took me less than 2 hours including removing and refitting.
    Andy
    1999 HDJ100 VX Active, 160K miles and everything works (hooray)
    http://www.gw4x4r.co.uk
  3. #3
    Super Moderator Andrew Prince's Avatar
    Join Date
    Feb 2010
    Location
    Joburg, sunny South Africa
    Posts
    2,224
    Rob,
    There's a nice write up here - although it's for an 80 GX with a 1HZ engine, the parts are the same!
    http://www.landcruiserclub.co.za/cms/in ... y+boardman
    Let me know if you have an issue accessing it (LCCSA require you to register before you can access their site) - I could copy the write-up into a document and email it to you.
    The gasket kit part no is 04446-60070 for a 24v 80 series.
    Cheers,
    Andrew
    '98 80VX 4.2 TD (HD-FT) on Kumho KL71 285s, +50mm Ironman B lift, Airtec snorkel, CDL switch & "Gav's Custom Fabs" t/case bashplate and load-guard
  4. #4
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    Im not registered on there, could u email it to me? I could host the doc on dropbox and add a link here, if that's OK with the author on LCSSA.
    So far it looks like i need the following parts:
    1 04446-60070 Gasket kit, PS pump
    1 96711-19019 O ring, PS suction port
    6 90430-16168 Gasket, pressure feed hose
    2 90430-17002 Gasket, union bolt
    Take note i am replacing the pressure pipes and mounting a hydraulic winch, for future reference if you are rebuilding the pump you need:
    2 90430-16168 Gasket, pressure feed hose
  5. #5
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    Just called Toyota and its £58.06 for the lot, excluding the high pressure pipe. All those individual gaskets account for a fair bit , will shop around.
    Also 90430-16168 Gasket, pressure feed hose has been superseded by 44327-30030.
  6. #6
    Join Date
    Feb 2010
    Location
    Posts
    2,224
    Quote Originally Posted by Rob
    Mr. Rubie can't help you?
    Andrew
  7. #7
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    Quote Originally Posted by Andrew Prince
    Already have a respectable quote from Ian
  8. #8
    does anyone know anything about the variable ratio solenoid? i fitted a new pump a while ago as my steering was really heavy and for about 5 miles the steering was really excessively light- at that point something "clicked" in the steering stystem and the steering went back to being heavy. now im' presuming its the varibale speed solenoid that's not working properly- anyone know how to check or test? replacing it is NOT cheap
  9. #9
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    Quote Originally Posted by pugwash
    have you looked at the fsm? there are a few tests which can be done on the PS system and valve specifically, although for some you need a pressure gauge.
  10. #10
    Rob,
    Have you done this rebuild yet?
    Was it difficult? - mine is still weeping (did a patch job at the end of last year) so will need to tackle this sometime soon...
    J
    1993 HDJ80 4.2VX (Garage)
  11. #11
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    2,672
    Not yet, i only just got all the parts on Thursday, was waiting for some new power steering pipes. As that part came so late don't think that i will have time to do it before mid June, but will do a write up when i get round to doing it.
Similar Threads
  1. Rebuild Power Steering Pump
    By Dave Docwra in forum 80 Series
    Last Post: 10/03/2011, 18:39
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
