What is needed to go to 33s, and what extra is needed for 35's. I was hoping to go 35's.
As far as I can make out, I can either fit a 1.5" body lift OR a 2" ironman/OME lift to get 33's on comfortably, but up to what width ? will 285's fit (~11.3") or 305's (~12") fit without rubbing, If I need a larger (positive or negative ??) offset, are there wheels freely available that can be got cheap (70/80 series, l200 or Shogun for instance)
And so to 35's.... ~15% larger, so buggers up the speedo (fixable?) but what else, 35's seem to be in 12.5" wide fitments unless I go for silly tyres (simex etc) which would not be suitable for regular road use (may run 2 sets, 33's for general, and 35's for play depending on cost). If I fit the body lift and spring lift, will 35's fit without issue. Being an Auto, will I need a better trans cooler (assuming there is one already) or am I just putting too much into the drivetrain and should stick to 33's. She's going to be "used" offroad.
And finally, will 15" rims clear the brakes ? she's on 16's at the moment, there seems a much larger choice of tyres for 15" rims (33/12.5R15s, 35/12.5R15)... Likely to put Cooper STTs or BFG M/Ts on her for road use, but if I go dual wheel setup, then BFG A/Ts will go on.
Looking to get the lift / body lift ordered as soon as poss as one of the road tyres is down to ~2-3mm that's on her and don't want to spend out on a tyre when I'll be buying a new set shortly.
I see that brake lines should be okay with both lifts together, the Milners b'lift kit comes with the steering extrension, what about the transfer lever and auto gear lever ? (had to move the transfer lever on the Jeep with the body lift). I see the fuel tank is attached to the body, so no issues with the filler pipe. Anything else I need to consider ?
And is there anyone that likes lots of tea and biscuits and would like to help fitting it all
Gotcha's I know of:
Front shock top mounts seem "difficult" what about the rears
Rad shroud needs moving with the body lift
Steering extension.
C springs are going to be very hard until I get the HD bumpers and sliders on her.
Any advice gratefully received, the cruisers are very new to me and I would like to get it right 1st time if I can.
EE
Gotcha's I know of:
Steering extension.
EE
