don't like the adverts?
Results 1 to 7 of 7
Thread: Filter light
  1. #1
    Filter light
    Does anyone know what the yellow filter light means on the dashboard?
    It comes on when starting, and sometimes stays on for a little while.
    Thanks,
    Martin.
    0 Not allowed! Not allowed!
  2. #2
  3. #3
    Senior Member Olazz's Avatar
    Join Date
    Apr 2010
    Location
    Knebworth HERTS
    Posts
    1,086
    Where am I?
    Zimbabwe
    Re: Filter light
    Yes its the water in the fuel light.
    My Africa spec 60 has done it since new. As long as the light goes out no problem.
    1989 HJ60 That GOLD colour . Stock
    1992 HDJ81 That
    GOLD colour. The whole grocery list
    1997 FZJ80 Sadly Blue...colour has grown on me...just!
    2007 HDJ100 Sadly grey...but it'll do. SOLD
    Read my African travel Blog @ www.derfstravels.com
  4. #4
    Re: Filter light
    Do you mean there is water in my fuel filter????
    Is that condense water?
  5. #5
    Re: Filter light
    He few that the decanter under the chassis is full too of water.
    It is necessary to purge it by saw her of bottom
  6. #6
    Senior Member Rob's Avatar
    Join Date
    Mar 2010
    Location
    Bristol
    Posts
    3,008
    Where am I?
    UK
    Re: Filter light
    one of the jobs of a diesel fuel filter is to catch water. When it fills up you can usually drain it, there is usually a small tap on the bottom of the filter assembly. Not sure what its like on the 60. If that doesn't work you need to replace it. You may also find that the sensor could be faulty.
  7. #7
    Re: Filter light
    Purge the decanter, changes filter with diesel oil.
    Should be that good.
Similar Threads
  1. Fuel filter warning light
    By BlueRock in forum 90 Series
    Last Post: 29/08/2011, 17:58
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
