air con ideler pulley on 1KZ -TE
goodoldboy
Has any one changed this pulley - can you press the bearing out & replace it or is it blind? the main stealer is asking €96.00 + VAT might be cheaper to get one made - looks like 20 mins on the lathe + a bearing
Its a replaceable (double sealed) bearing, I don't know the reference number for sure, but it looks like 6301DUE.
A search on Simply Bearings produces this; 12mm ID / 37mm O/D & 12mm depth could be right, but you would need to check the dimensions of the old one to be sure:
http://simplybearings.co.uk/shop/ad...arch_in_description=0&keywords=6301&x=18&y=10
Of all the options, this would be my choice:
http://simplybearings.co.uk/shop/p6...ove+Ball+Bearing+12x37x12mm/product_info.html
It shouldn't take long to hook it out and order up a replacement.
Hope this helps.
Bob.
Job done the bearing reference was spot on bob - thanks again .Also a pleasant surprise at the main stealer - all 3 belts for €30.00 inc. vat :D
