don't like the adverts?
Results 1 to 15 of 15
Thread: Programming a new keyfob
  1. #1
    My landcruiser only came with the master key, no remote fobs. I read instructions online to program a new fob by pressing the reset button on the alarm box behind the radio so ive bought a fob on ebay.
    Took the radio out today and found the black box cable tied to the steel bar with tvss on the label, there is no metal plate on it to prise back and as far as i can see there is no reset button, there is a plastic guard riveted over the plug connector which i prised off but nothing underneath. I even took out the unit and opened it up, i cant see any reset button on the circuit board!
    Am i missing something or do the D4D engined colorados have a different alarm?
    0 Not allowed! Not allowed!
  2. #2
    Senior Member
    Join Date
    Jan 2011
    Location
    Milton keynes
    Posts
    1,082
    Guyana
    Re: Programming a new keyfob
    I cant remember exactly how I reprogrammed mine, but I think it was a guide for a toyota Corolla, which uses the same key fob
    I did something along the line of getting in the car. holding down my finger on one of the buttons, I think the open Button, meanwhile detach the key fob battery for about 10 seconds and then place it back with your finger still on the button. Then it should work!
    Give it a go!
    1997 Toyota Landcruiser Colorado
  3. #3
    Senior Member sae70's Avatar
    Join Date
    Aug 2010
    Location
    Witham, Essex, United Kingdom
    Posts
    2,610
    Where am I?
    UK
    Fiery's not a D4D Collie, but to synchronize my Key-fobs to the alarm all I had to do was hold both buttons down for 2 seconds while in range of the vehicle and Voila
    Regards, Steven
    02MY LWB D4D GX Collie called Swampy
    98MY SWB TD GX Collie called Fiery (Garage) Sold and living in Switzerland
  4. #4
    Cheers guys will give those a go tomorrow.
  5. #5
    Senior Member
    Join Date
    Jan 2011
    Location
    Milton keynes
    Posts
    1,082
    Guyana
    Quote Originally Posted by sae70
    In the manual it says that, but it never works....
  6. #6
    Super Moderator Chris's Avatar
    Join Date
    Feb 2010
    Location
    Chesterfield, Derbyshire
    Posts
    11,767
    Where am I?
    That just re-syncs an existing fob to the original alarm. It does not programme a completely alien fob to the alarm. If it did, all you would need to do to steal a car would be to stand next to it and press both buttons on any fob and you'd be away!! On the non D4D you have to press the reset on the ecu and then activate the fobs one at a time. The D4D must therefore be different. The answer cannot be in the fob alone. It must include the alarm unit in the vehicle.
    R.I.P
    Silver Phoenix
    95 HDJ80 GS in THAT grey colour, 35's, 4" EFS, AO drawers, ARB front, Frogs at the back SOA bash, Come Up 9.5, Heat Ex, BW water tank, still more to come
    '93 VX Oil Burner ARB, TDS, OME with no plans. Yet
  7. #7
    I can see an expensive visit to Mr T may be in order!
  8. #8
    I've got an '02 Colie D4D LWB version and had to do this some time back. There is two sets of programming: 1- Programming the key buttons (lock/unlock) and 2- Programming the immobilizer
    I could'nt get a key with the right shaped blade and since my only original was already bent I ordered one from MrT (160) and programmed it myself... Wel got it working perfectly after the fith attempt...
    This worked for my (KDJ95)
    TO PROGRAM THE IMMOBILIZER (Do this first)
    1.) All doors closed - no key in ignition
    2.) Insert MASTER key
    3.) Turn key from LOCK to ON five times (x5 and end on ON)
    4.) Open & close the driver's door six times (x6)
    5.) Remove Master key
    6.) Insert New key and wait 60-70 seconds
    7.) Remove New key
    8.) Open & Close driver's door to End
    TO PROGRAM THE LOCK/UNLOCK /PANIC BUTTONS:
    1.) Turn Key off..remove key from switch and open drivers door.
    2.) Insert key into ignition switch and remove (don't turn it)
    3.) Lock & unlock power door locks from drivers door switch 5 times @ 1 second intervals.
    4.) close & open drivers door
    5.) Lock & unlock power door locks from drivers door switch 5 times @ 1 second intervals
    6.) Insert Key into ignition switch and turn from lock to on twice and remove key
    7.) Door Locks will cycle automatically from lock to unlock twice to confirm program mode has been entered.
    8.) Take the original remote, BRIEFLY press the unlock and lock buttons simultaniously... and release...then press the lock button and release...If successful the system will cycle the locks from lock to unlock... (Repeat step 8.) for replacement key)
    Important-You need to repeat step 8 for each remote you want programmed..when all your remotes are programmed moved to step 9
    9.) Insert ignition key and remove to exit programming mode..
  9. #9
    Tried all the above methods today several times and got nowhere.
    I was wondering if maybe ive bought the wrong chip, are there different ones? It fits fine in the key, has two buttons and has 'valeo' moulded into the back with a label that says:
    R119.3
    89071-0D020
    The led lights up when i push either button so i assume that means the battery is ok.
    Any more ideas before i call Mr T?
  10. #10
    Super Moderator Andrew Prince's Avatar
    Join Date
    Feb 2010
    Location
    Joburg, sunny South Africa
    Posts
    2,232
    Where am I?
    Quote Originally Posted by stu-pid
    Go into your local locksmith and see if they can help. Toyota is your last (and most expensive) resort.
    Andrew
    '98 80VX 4.2 TD (HD-FT) on Kumho KL71 285s, +50mm Ironman B lift, Airtec snorkel, CDL switch & "Gav's Custom Fabs" t/case bashplate and load-guard
  11. #11
    It turns out that the key i got with the car is the valet key which cannot be used to program new keys. Because i only have the valet key Toyota cannot supply me with a replacement key without replacing the alarm ecu as well at a ridiculous cost!
    So my next question is can i permanently bypass the factory fitted immobiliser in some way so that i can fit an aftermarket alarm/immobiliser system that operates the central locking?
  12. #12
    On mine
    The Immobiliser works directly from the ECU using a chip in the Key
    The Alarm (which works the siren/remote locking etc) works from a seperate toyota alarm unit, in conjunction with the Alarm fob on the keyring.
    (This is why if you have the key you can still start the engine with the alarm blazing away)
    You can indeed remove the Alarm completely (and fit an aftermarket - The higher end TOAD alarms are best in my experience) but you would still need at least one Key that is mated to the Immobiliser/ECU
    If you need a new KEY - Assuming your Key starts the engine and its not the master, there are places that can scan the key in exactly the same way that the toyota ignition barrel does, read the code and place the same code on a new key (effectively copy the code on the chip as well as cut a key blank) but they would need the key (which is OK if your near someone that can do that, I wouldn't recommend posting your only key!!)
    If you need a new ALARM FOB - go on ebay then as Chris says find the reset button on the Alarm ECU, and follow the previous instructions
    I think on Later Vehicles Toyota have just stuck the Alarm Fob inside the Key - i.e. if your remote central locking buttons are on the handle of the Key - you have a model where the Immobiliser chip and Alarm Fob are built into the same Key mould - they are still I believe seperate units as such... But I'm only going by roughly whats inside the vehicle.
    Hope that makes sense, it is early....
    Dave
  13. #13
    Senior Member warrenpfo's Avatar
    Join Date
    Jul 2010
    Location
    Maidenhead, Berkshire
    Posts
    2,828
    Where am I?
    Not sure if i can help but my Toyota Computer has a section on pragramming keys and so long at the car is a 2000 or older model might be able to help you.
    I have never had to reprogram a key so am not sure how it works but seen as it plugs into the car would assume it might be able to do the job for you.
    I would be happy to give it a go only problem is that i am Maidenhead based.
    1995 HDJ81, Stock Standard...for now
  14. #14
    Quote Originally Posted by warrenpfo
    Thanks for the offer warrenpfo your not too far away really but i think Ive sorted it, i contacted the previous owner whos details were on the logbook and they think they've still got a key for it & are going to send it to me so fingers crossed its the master key! I also contacted an auto locksmith who can program new master keys in to toyota immobilisers for 100 which is worth knowing seeing as Toyota say it cant be done!
  15. #15
    Quote Originally Posted by Ducktape View Post
    7.) Remove New key
    I just did this and the remotes (2) did make the locks cycle but the remotes still do not work.
    Any idea od the problem?
Similar Threads
  1. Replacement keyfob battery
    By James Rothwell in forum 80 Series
    Last Post: 01/10/2010, 11:05
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
