200 Series Door handle Removal
Pureimage
australia
Does anyone know how to remove the door handles of the 200 Series landcruiser?
I have the small piece off but trouble removing the main piece. Every other car with handles like this seem to just slide out. Not this one.
Anyone able to give insite?
Do I need to remove the door trim to do?
If so how do you do this without breaking anything
thanks
Mines a 90 series so may well be different but on mine the metal rod is is bent at the end 90 degrees and held to the handle by a plastic loop . That same plastic runs along the longer length of metal bar to the lock . It's only about an inch long and looks like a sleeve but its actually a clip , push the handle back in the hole until you have just enough room to flip the clip off the bar and then the rest just lifts off at the loop . It's hard to explain and yours might be different ?
