After ignoring the clues of a failing alternator bearing for around 3 months I found myself at 8am broken down on the A46 near Leicester. Stripped out the old alternator on the roadside and called a local (ish) motor factor who could supply a unit by 2pm - so all I had to do was travel 15 miles or so - it turns out the AA are not allowed to carry such a thing as a emergency fan-belt now (I was hoping to just drive on battery power - 2 batteries, old school diesel, not an issue). So on the back of a recovery truck it was.
I go to the auto-factors - two problems, 1st its the oval plug and not the round and 2nd it was only a 60amp unit (not the 80 amp I had - I wont go into the battle about my original alternator not looking brand new for the core unit exchange at the auto-factors
- finally convinced them that dirt is not damage
). Anyway needed to get rolling - had a caravan in tow and off road trial the next day.
Fortunately I had already bought an oval wiring pig tail for £8 off ebay - so that was a case of just mapping wires across - the new alternator was fitted and I was up and running again - unfortunately just touching the winches really made this alternator scream!
So I bought one of the 120amp units from Ebay for less than I paid for the 60amp unit
This is the 60amp unit fitted
Left an old 80amp unit, middle new 60amp and right 100 series 120amp
As much as I could measure, the only difference being the smaller units were ø120mm (80 amp) ø100mm (60 amp, but with longer mounts) and the 120amp unit being ø130mm - all clocking and terminal positions the same.
A trail run shows the bracket does foul the larger diameter (as mentioned in above posts)
Yellow marks shows how much needed to come off the bottom edge and top of the slot.
This is the 120amp fitted
Close up of the bracket.
I took a template of the bracket before making the new clearances, Im going to make a new one with the bolt holes to the water pump offset to allow for the difference.
