Hi Guys
I've recently bought a '94 Series 80 4.2TD, Auto. It needs a bit of TLC and a good service, and I've got a long list of jobs that need doing.. I'll post up some pics etc in a separate post.
I'm already mid-way through replacing the front exhaust section (rust on the front box joint & damaged flexi). But one issue I have immediately is that its leaking coolant (probably a drip every second or so). On good inspection I've discovered seems to be coming from around the water pump housing (its more or less around the lower part of the housing which drives the engine cooling fan.
I'm planning to give the cooling system an overhaul with some new parts and a good flush. As the water pump seems to be hidden behind the timing belt, I guess I may as well replace this part now along with the idler / tension spring, so I know this job is done. It last ad a cambelt approx 3 - 4 years ago, but the service history for the past 6 years is a little patchy, so not sure if it had just belt, or belt + idler etc changed.
Having been a little shocked by the price of the Water Pump and Timing belt Idler from my local Toyota dealer, I was wondering whether anyone has any experience of the Milner parts? Their Idler seems to be a Koyo part, so I'm reasonably comfortable with that. But what about the quality of the water pump?
Any comments appreciated.
Al
Al
