nielsc
- Jun 28, 2016
An update,
the last couple of days the glow light goes on and off more frequently during driving, at first it would not light up at all, very strange. It seems that when I accelerate the lights comes on, but I'm not really 100% sure.
Whilst reading on the internet I found the glow light also is used as a check engine light ? This maybe explains why it is lighting up? If so, how do I check the codes ?
Also I found out the function of the EGR and the heather screen are combined in the emissions ECU.
Since my EGR has been removed this could have to do anything with this ? The plugs from the actuators are plugged in, and the vacuum lines are looped to each other.
I've also read a topic on here that you need to ground the heather screen to the exhaust manifold as it is grounded trough the EGR valves, that I don't have anymore, this could explain why the relay is burnt due to bad ground and high current. So now I have grounded the heather screen to the ex manifold.
