Trevor
- Jul 25, 2010
After giving Lil' Blue a dunking in the Essex floods last year (Essex Trip )and taking water into the engine, this thread will attempt to document the repair process. This will be the biggest job I've ever done having never worked on the bottom end of an engine before.
It all starts last year with me removing the head after having done compression checks HERE
Now the snow and cold weather has lessened it's grip, it's time to continue....
In order to be able to remove the sump I decided to approach from underneath rather than lift the engine.
First job is to split the lower ball joints, these were really easy with a screw type splitter. Note that you don't need to remove the brake caliper or move brake lines.
Next is to disconnect the the driveshafts from the front axle, there is no need to split CV joints. Instead you can pop the tripod joint housing out of the axle itself as there is enough movement in the suspension after splitting the lower ball joint. I had a buddy pull the driveshaft assembly slightly outward to expose a gap between the tripod joint housing and axle to allow me to slide a 3mm piece of metal bar into the gap. With a combination of levering and hammering on the bar, the spline shaft eases out after overcoming the resistance from the snap ring. If you have not already drained the diff oil out it will now leak so have a container ready to catch this.
You can now swing the whole assembly outward and tie it out of the way.
Use something to cover the spline ends to keep dust and dirt out.
Now you need to mark the front prop and undo, once done you can now remove the front axle, this is a bit of a pig. I removed the bolts from the carriers either side of axle at the front, 3 bolts on the N/S and 2 on the O/S.
You will see a hex bolt coming through to the underside of the front crossmember which is part of a rubber mounting bush, normally this will undo but the hex nut just kept spinning in the bush so to get round this problem you need to split this mounting from the axle case by removing 2 bolts above the crossmember. The bolt to drivers side (bolt at top "pointing" down) was removed by putting a 17mm spanner (open end) and the spanner pointing roughly forwards, then using a breaker bar pushed up into the engine bay I levered against the spanner. Shock force does not work here, it needed sustained levered force to get the bolt moving.
The other bolt on the passenger side and hidden just above the crossmember (bolt head at bottom "pointing" upwards), this needed me to go and buy a 17mm flexible head ratchet spanner. I had unbolted the axle from the side carriers and while my buddy tried to slip the ring spanner around the bolt head, I was on the floor at the front of the truck pushing the axle upwards with my feet to give enough space to get the spanner in (ok ok I could have used a jack).
The spanner faces the rear of the truck and again a levering action being done against the spanner with the breaker bar. The bolt would only move a couple of mm at a time due to the limited space the spanner was in and very little sideways movement available, so lever, reset spanner, lever again and so on. Finally it got going but as the bolt head moved downward we couldn't get the spanner off and as it was a ratchet head we couldn't tighten it back up again. This time the jack came out and I managed to move the axle just enough to get the spanner out, we then continued with the open end until the bolt was free.
I put a block of wood underneath the truck and after a bit of wiggling the axle dropped down.
Now all this is out of the way you can finally see the sump, this has a plastic and foam stoneguard which is attached to the sump case itself via 4 bolts, however on my truck the foam was so stuck to the sump that it could not be removed without it breaking into pieces plastic and all. You need to remove this to expose the sump bolts themselves.
Once you have removed all the bolts that you can see, you now need to remove the flywheel inspection panel at the rear of the sump, 4 bolts will allow you to take this off and hidden above are a couple more sump screws. My sump was well and truly held on by a good bead of sealant. Using a lump of wood on the front face of the sump, "encourage" it's release by hitting the wood with a hammer a few times to break the seal.
At this point you can't remove the sump as it will not clear the oil pickup pipework, so with the sump split from the engine, you have 2 x 10mm bolts and 2 x 10mm nuts to remove. in the photo you have 2 supporting legs at the left and right hand side of the picture which are held on with 1 x 10mm bolt, the oil pickup pipe union is near the middle of the picture and has the 2 x 10mm nuts. The first nut can be done with a standard 10mm spanner, however the second nut needs a 10mm aviation spanner (a long spanner) to be able to reach it.
Do not forgot to disconnect the oil level sensor connector...............I didn't and broke it.
Once these are undone you can remove the sump with the oil pickup pipework inside. I removed the pipework and then put the sump back on to stop dust getting into the bottom end of the engine.
Top tip.... tie the end of the spanner to your wrist as it's a t@*t to retrieve when you drop it into the sump.
Finally I have access to the bottom end
Part 2 will continue after I've had the pistons out etc.
