Hi all
I recently acquired a Toyota Granvia which has the 1KZTE 3.0 Diesel engine fitted. The Gravnia seems to be the love child of the Hilux engine with a Hiace type body. I bought this to turn into a camper while having Toyota reliability.
Upon driving it last week the engine loss all power, all warning lights came on and it coasted to a stop. I had a look under the bonnet and everything looked ok (battery connected etc.). The car started back up, drove 10 miles and the same thing happened.
I’ve been troubleshooting the car over the last week and believe that the spill control valve may need replacing. It feels like fuel isn’t being delivered into the engine. The engine doesn’t cough or splutter when this happens. It just cuts out as if there’s an immediate cut off to the fuel.
I’ve bought a new SPV which I’m due to fit but have also acquired a secondhand 2.4 fuel pump (with SPV) which is apparently in working order. Does anyone know whether the 2.4 SPV is interchangeable with the 3.0 pump?
I’m hoping to change the SPV without removing the pump. This does seem possible, although fiddly and I’ve bought a flat 32mm fan spanner to help.
If this doesn’t cure it I was thinking of sending off the ECU to be looked at. I’ve also read there’s a Spill Control Relay which is under the dash, however I can’t find any new ones available online. Does anyone know where these can be acquired?
Welcome any thoughts on this one.
Mike
Mike
