Iwan
- Mar 28, 2011
After doing some research on this kind of modification, I've decided to give it a go!
A couple of weeks ago I managed to buy a cheap 1kzte engine from a year 2000 manual colorado. Unwarranted from the buyer but nothing is impossible.
Its got real good compression, still had toyota red coolant in it, been handled quite badly in the breaker's yard, the clutch is worn
I hadnt got a pic when it arrived but had stripped out all the sensors and embarked on removing the "e" pump.
Timing belt wise they're very easy to work on.
Was a bit oily to use the camera when removing the injection pump pulley, but also an easy procedure.
I have removed the egr and blanked that off, when looking at the inlet manifold noticed the restriction that there is in there. I've removed both of the flaps that control the air inlet piece and have put bolts in place of the shutter pin.
This is the Zexel made pump that I managed to get hold of. It was on a 2.8td Pajero.
There's a few things that you need to strip off the pump. It has a water controlled cold start advance and retard system seen on the pic before, I've read that you can loose that item and have read that the inner mechanism that opperates the advance/retard can break off and badly score the inside of the pump.
But at the moment I have had to take the lower water feed pipe off (bottom of the last pic) as it gets in the way of fitting the pump on the engine.
It fits on with ease really, just had to grind a bit out of the engine mount to allow the pump to fit in. Then tighten the pump drive bolt and refit the cambelt pulley.
A pic of the inlet manifold opened up. Should let quite a bit more air into the manifold or at least there isn't an obstruction.
Had to take the collie sump off and put a IFS sump on as the collie sump will be clashing with the front axle as intended to fit into a 70 (of course!)
Was happy to see when I took the sump off as it was very clean and no sign of swarf etc.
Last night had a pop at getting it running, but had a limited amount of time and very poor fuel.
Will have to add a pic of the staring scenario off my mobile later.
I'm quite confident as its been done before but it's new and interesting to me.
