Elkhunter
- Dec 29, 2014
Ok This is a new vehicle to me. and this problem has been going on for about a month. It is intermittent, but this is how it goes down... First the battery light will come on followed by the voltage gauge spiking and then all the other warning lights come on. These lights include (when all on) the battery ABS VSC traction and brake light. The dealership said I needed a new alternator as it was putting too much power into the system so I had that changed but the problem still persists. I have checked all the wheel speed sensors with an ohm meter and the two fronts are constant at .95 and the two rear are constant at 1.25 so I think they are working. This seems to be an electrical problem but I'm not sure what the deal is. No fuses burned out???? My battery tests good. Anyone have a clue? Thanks
