70 series gearbox woes (
Hi,
I am having some bearing (humming noise) that appears to becoming from the
gearbox, whilst in 3rd, 4th, and 5th gear.
The noise get proggresivly worse the faster you go, its definlty coming from
the gear box area, and gets more noticeable once vehicle/gearbox has warmed
up.
Has anyone had anything similair happen?
Could it be related to the clutch as this appears to be on the way out as
well?
Before dismantling the box has anyone got any suggestions?
The noise disappears if I lift my foot of the throttle or put the clutch in,
and only becomes noisy when in 3rd and above.
Thanks in advance.
Martin.
Checked by AVG Free Edition.
Version: 7.5.441 / Virus Database: 268.18.3/694 - Release Date: 20/02/2007
13:44
Hi Martin,
Could it be the rear UJ on the propshaft? Worth checking.
Also have you checked the gearbox oil recently, what is the quality like?
Anything on the drain plug?
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
HI Julian,
Thanks for you reply, I check the UJ at the weekend and let you know how I
progress...
Also I will drain the oil and see what its like, hopefully no mud and water
has got in :)
Another question:
Does anyone know if the gearbox out of an LJ70(F reg, old round light model)
is the same that=92s in a KZJ70 (KZ-T engine, M Reg, 1995)?
I have tried searching the web for info but cannot seem to find much on the
rarer KZJ70?
Martin.
[mailto:[Email address removed]]
from
coming
like?
21/02/2007
21/02/2007
Version: 7.5.441 / Virus Database: 268.18.3/696 - Release Date: 21/02/2007
15:19
Hi Martin
I doubt it-these are the same bodies but different engines( 2.4 and 3.0) so
I think the gearboxes won't fit...
cheers
Lubo
Another question:
is the same that?s in a KZJ70 (KZ-T engine, M Reg, 1995)?
rarer KZJ70?
Martin.
15:19
Version: 7.5.441 / Virus Database: 268.18.3/696 - Release Date: 2/21/2007
3:19 PM
Thanks Lubo, that=92s what I was suspecting.
Martin.
3.0)
on
15:19
Martin,
Looks I was wrong,but I still don't believe it...
But here we have guys with knowledge and you should here from them :)
it was only my modest opinion...
cheers
Lubo
----- Original Message -----
To: <[Email address removed]>
Sent: Thursday, February 22, 2007 7:47 PM
Subject: RE: [ELCO] 70 series gearbox woes :(
Thanks Lubo, that?s what I was suspecting.
Martin.
Hi Dennis,
Thanks for the information, that=92s defintly worth thinking about doing
depending on what's wrong with mine, hopefully I can have a look next
weekend.
Thanks again.
Martin.
__________________________________________________________________________
21/02/2007
21/02/2007
Version: 7.5.441 / Virus Database: 268.18.3/699 - Release Date: 23/02/2007
13:26
Hi,
Dropped the gearbox out at the weekend the UJ's look ok, my friend has
opened the box up and confirmed the worst, water in all the bearings.
He is busy rebuilding it with new bearings etc... this week and also its
having a new clutch as its wearing.
It looks like the water has entered the box from the breather at the top.
(It did go UP a stream for about 100-50 Metres, up to the bonnet :). The
breather is a one-way valve and looks pretty pathetic.
I will be running 2(think there is one on the transfer) rubber pipes from
the gearbox/transfer up the edge of firewall somewhere. Also going to do the
same with DIFF's.
If anyone has any gotcha's on this, please let me know.
For instance i have heard/read somewhere that the oil/gas that comes from
the gearbox up the pipe is quite toxic/corrosive? Will a rubber pipe do? Am
I going to be intoxicated whilst driving :) ?
If all goes well a friend in his LJ70 and myself(KZJ0) will be attending
Salisbury Plains(We need fill the form out I guess, Julian?)
Martin.
on
Version: 7.5.446 / Virus Database: 268.18.7/711 - Release Date: 05/03/2007
09:41
