Hi all, I have a 1996 75 Cruiser ute.
someone in her previous life changed the front hubs and Rotors.
Hubs measure 106mm.
Rotors measure 302~mm with 106 centre hole.
problem is I can't find out where these hub/ rotor combination comes from.
I can find 283mm rotors with 106mm centre hole or 302mm rotors with 100mm hole but not the combo I have.
Q/1-does anyone know what this combo is from?
Q/2- Will a 283mm rotors work or will the calipers be mis aligned?
btw they have 6stud just in case your wondering.
Hubs measure 106mm.
