PedroAraujo
- Mar 17, 2018
hi,
I have a problem with my windscreen washer pump working slow, dribbling out of the nozzles. I measured 12v at the pump on the wiring and changed the pump, no change. The pipes are all clear so there is no blockage, cleared these with an airline.
Question is, I have checked the fuses for the wipers and all ok, getting 12v at the pump, am i looking for a relay which is shot and needs replacing? Has anyone had the same experience?
I have read on line that some Toyotas have a 20a relay on the wiper switch which sometimes goes bad and this could affect the power to the wipers/ pump.
Any ideas where I can locat the relay? What else can I check?
Thanks Puff.
Thanks Puff.
