Again, for those who may be interested.....
When I asked the group if there was a make of water pump I should NOT buy,
there was no negative response. So I went ahead and got one off the shelf
from my small local importer of aftermarket parts. I was amazed he had one
on the shelf, but he also stocks 92 different types of brake pads so I
guess I should not have been.
The pump is branded 'SIL' - 'Industrie Saleri Italo' and the label
description is -
'PA 1152, Toyota Landcruiser 4200 diesel etc. 1610019235' There are also
3 ISO standard seals printed on the box too.
Apart from the gasket it was also supplied with a pack of 4 replacement
studs for the fan mounting.
Although an Italian company there was a further ID cast into the pump -
' 02 X - GMB Japan'. - Interesting !
Cost - 60 quid, which compared with Milners delivered in UK and VAT added,
is about a fiver cheaper. (Obviously vastly more expensive if sent out here
to me direct).
It was also time to replace my front discs as I am sure they are the
originals and the shimmy was getting greater and they were definitely
beyond the 2mm wear limit. So once again my man had various styles of
replacement for the TLC on the shelf. This time he had Italian made
'Brembo' discs. Mine are the 286mm X 25mm version - they are a smaller
diameter of the two different variants fitted to the model 80 after 1990, I
think the other is 310mm X 32mm. The box label reads thus -
Brembo. 09.5866.10 - applicable to Toyota, 43512-60050
(The latter being the Toy parts number)
Cost - 103 quid which would be about 25 more than Milner's in UK.
All bits are fitted and the 80 is running well.
I can't get well made wiper blades in this place but can get pumps and discs !
Jon
'92 HZJ80 ex UN surplus in Bosnia - pictures of parts were taken for anyone
sadly interested !
description is -
to me direct).
Jon
sadly interested !
