80 series final drive ratios
Hi All,
I'm trying to establish what final drive (a.k.a. differential, a.k.a. ring
and pinion) ratios came on european spec 80 series. I'd like to be able to
re-gear my cruiser to run 35" tyres and still tow a car trailer without
frying the clutch.
Standard ratios from the factory were 3.727 (41 teeth on the ring, 11 on the
pinion) and 4.10 (41 teeth on the ring, 10 on the pinion).
All cruisers have an axle code on the build plate found on the bulkhead in
the engine bay. The code for diff-lock equipped axles is K304 for the 3.7
ratio diffs and K294 for the 4.1s. It will be in the middle of a row of
other codes for engine, transmission body colour etc.
I know that my manual 1990 HDJ80 has 3.7 ratio diffs. Someone at Toyota GB
is trying to tell me that all UK spec 80 series had 4.1's. I've a suspicion
that maybe manual cars had 3.7s but automatics had 4.1s.
Can anyone look at their build plate and see what axle code they have?
Hopefully this might establish an accurate picture.
Thanks in advance,
Toby
1990 HDJ80 UK
___________________________________________________________
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
Toby
My manual 1996 1HD-FT has K304 H151 F
Christopher Bell
| the bulkhead in the engine bay. The code for diff-lock
| equipped axles is K304 for the 3.7 ratio diffs and K294 for
| the 4.1s. It will be in the middle of a row of other codes
| at Toyota GB is trying to tell me that all UK spec 80 series
| had 4.1's. I've a suspicion that maybe manual cars had 3.7s
Hi Toby,
Mine are K304. It is a manual 1HD-FT.
Ian Rubie
Hampshire UK
96 HDJ80 2.5" OME Lift
Christopher, Ian,
Thanks for your responses; it looks like UK spec manual diesels all had 3.7s
then.
Is there anyone with an auto who could chip in?
Thanks,
Toby
1990 HDJ80 UK
All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
http://uk.docs.yahoo.com/nowyoucan.html
AdBlock Detected
