Jason Read
- Apr 1, 2018
Hello, My drivers side wheel bearing kept coming loose. Pulled apart completely and found that the thrust washer has grooves in it both sides. The spindle looks not too bad. Does anyone know how to tell if wear is excessive.
There is a very slight ( visual but hard to feel) wear area where the inner race sits. But no out of round or serious wear evident. Also how much play should the drive flange have. Drivers side is more than the passenger side. Splines on axle and flange do look a little worn.
I have a wheel bearing kit arriving. I could do cv's and spindle if I really have to but would prefer to not have the expense right now! The cv joints are not clicking or anything. Just deciding weather to just do bearings and have another look in a year or so. Cheers
