roy
- Feb 4, 2011
hi can anyone help with abs issue ?
i have done the flashing code to check the problem and i am getting code 33 34 which are the rear sensors.
i have replaced both and did a reset to clear the abs light , but after a couple of minutes of driving the abs light comes back on.
and checking the error codes i am getting the same rear sensor codes.
can anyone shed some light on what may be the problem,
