Hi all, searching the forums for a supplier of a blanking plate/kit for the ACSD, they must be able to post to me in Spain, many thanks in advance.
regards
Dave
regards
Dave
What is an ACSD Dave?Dave 2000 said:Hi all, searching the forums for a supplier of a blanking plate/kit for the ACSD, they must be able to post to me in Spain, many thanks in advance.
regards
Dave
Sorry mate, Auto Cold Start Device, it is a common abbreivation from the trade. This device hold the throttle on fast idle when cold and can on some vehicles advance the pump/ignition timing, on the 80 they tend to wear and cause a loud ticking noise, they often leaks as well, if left they can break off inside the pump causing extensive damage. Take it off and all will be well, this is similar to the 24v starter system used on the 80, it is completely unnecessary unless you live in Siberia. It is often removed and blanked off resulting in a leak free, quieter and more stable idle. The blanking plate kit is about but I am damned if I can find one here in Spain.Bat21 said:What is an ACSD Dave?Dave 2000 said:Hi all, searching the forums for a supplier of a blanking plate/kit for the ACSD, they must be able to post to me in Spain, many thanks in advance.
regards
Dave
