Ken Brenton
- Aug 23, 2012
I am planning to overhaul the AHC suspension on my return to UK (currently in Jakarta on contract) later this year prior to some European touring, hopefully some trails included in Portugal or somewhere similar.
I need some advise on what I should just change out.
I will go and see Pleiades to check out and recondition the AHC systems but at the same time was thinking of fitting new rear springs and air helpers.I have already received rough quotations which seem reasonable to recondition the AHC system and fit springs and adjust torsion bars at the same time.
Anyone any advice as to what products to use or if I should first inspect before just replacing the springs.
Are the springs OEM only or can other suppliers meet the requirements? Anything else I should consider replacing whilst at it?
The vehicle is a 2001 100 series VX with 4.7 petrol engine and has done 135000 miles. I fitted LPG when I first bought the vehicle with a 90L tank replacing the spare wheel and will be adding a rear wheel carrier and some rear storage ready for touring/camping. So a bit heavier in the rear than originally.
The suspension seems to be working fine at the moment and all the height and sport controls also working. I would just feel more comfortable, given the age and mileage of the vehicle, to be safe rather than stuck in crawl mode in the middle of nowhere or am I being over-cautious after reading about AHC mishaps?
