Unforttunately my air con has stopped working.
The compressor is not kicking in & there is no voltage going to it.
I wondered if the gas was low & not operating a pressure switch (is there one??), been down to my local kwik fit today for a recharge in case this was the problem, but alas not, now I have to reace the wiring back from the compressor (it disappears into the loom) and work back from there!
Does anybody know the location of the relay that operates the compressor?
There are a bunch of relays in the drivers side footwell behind the kick panel & none of these click when switching the air con on, is it one of these & I have a faulty relay, or has Mr T tucked it away in some obscure place???
I will run a 12v temporay wire to the compressor from the battery later just to double check that it does engage, in the meantime any advice appreciated as this stuff is not my forte!!!!
Andy
Andy
