Hi Guys
Ok just to ask a few silly questions.
The air filter is the only way for abrasive dirt to enter the engine is it
not.
Is it not this dirt that is responsible for damage and premature ware within
the engine so it does make sense to exclude as much as possible.
But and here are the questions how do you know how much air the engine needs
at any given time.
If it gets too little will it start to complain.
Is the speed and volume of the air entering the engine determined by the
road speed and the pulling power of the pistons or just the pulling power of
the pistons.
Just thinking, at a stand still with the engine running even at high revs it
still gets enough air to work properly.
As for the ram air effect with a snorkel would it not keep out more dirt if
it was turned backwards in bad conditions.
If you look at all the big trucks they all have their filter snorkels to
the side of the cab.
So this must be to protect those expensive engines is it not.
Can you install a pre filter filter on the cruiser in the inlet pipe to the
rear of the head light or would this constrict flow.
cheers
john 92HDJ 80 1HDT
not.
at any given time.
the pistons.
cheers
john 92HDJ 80 1HDT
