Beau
- Jan 28, 2011
So here's the issue...
When I lock the car with the fob (activating the alarm) my battery is somewhat draining overnight. The longer the time frame the more you can tell via how slow the starter turns over. If I lock the cruiser with the key I don't have any problem the days I start her up.
I've ran a amperage test and it doesn't show any kind of mass draw on the battery with the alarm engaged. 0.05/0.06 amps as the light ticks on and off. and 0.03 without the alarm engaged. I've let it sit for about a minute and readings are constant. So from this standpoint it seems the alarm isn't draining the battery, but I know for a fact when I use the fob couple days ahead it'll turn over sluggish when starting.
Any ideas what the problem could be? I'll be checking out the siren area over the following days and checking all wires/connectors for corrosion. Maybe a power leakage through something?
