Alternator upgrade HJ60
Hi all
Anyone help me with a upgrade to hj60 alternator as it is only 40 amps....may have a rewire but a replacement must be possible
dont wish to go down the way of STERLING POWER PRODUCTS to exspensive.
Hope some one can help this is the first time i have chucked a question out....Who nows may get it sorted
Cheers....DANIEL
From: [Email address removed]: [Email address removed]ubject: [ELCO] The EU Strikes againDate: Sat=2C 24 Jan 2009 21:25:55 +0000
Hi All
Greetings for 2009
You may already know about this...
http://www.r2rc.co.uk/home/content/view/27/97/
If you didn't then be worried.
Please tell everyone you know.
Dave Harris
Twice the fun=97Share photos while you chat with Windows Live Messenger. Learn more.
http://www.microsoft.com/uk/windows/windowslive/products/messenger.aspx
Daniel,
Most alternators are fairly standard fittings, if not adapting one is
not difficult. As long as you have one that is 12 volt and a high enough
amperage then put it in. There is no worries about over producing etc. On
that vehicle you would be OK with a 70A one. Try your local breakers yard
for 4x4's or larger saloons. Should you find one with a connector that
matches it will be a bonus, try sticking to Toyota.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Cheers clive
Will do i will get on to google may take a look at the alternators for the 80 series who nows may get lucky....
cheers...mate
Date: Thu=2C 29 Jan 2009 10:36:49 +0000Subject: Re: [ELCO] Alternator upgrade HJ60From: [Email address removed]: [Email address removed]aniel=2C Most alternators are fairly standard fittings=2C if not adapting one is not difficult. As long as you have one that is 12 volt and a high enough amperage then put it in. There is no worries about over producing etc. On that vehicle you would be OK with a 70A one. Try your local breakers yard for 4x4's or larger saloons. Should you find one with a connector that matches it will be a bonus=2C try sticking to Toyota.Regards=2CClive MarksHome: +44 1293 514600Mobile: +44 7821 491897Crawley=2C West Sussex=2C UK.
Check out the new and improved services from Windows Live. Learn more!
http://clk.atdmt.com/UKM/go/132630768/direct/01/
