AndyCook
often after a greenlaning trip, when i try to start my LC - it wont start,
putting the auto gear lever in N or pulling back on lever when in P whilst turning the key usually lets it start
and to fix it i go under the vehicle and loosen off and adjust position of the gear lever linkage.
its now at end of adjustment... so even harder to start the engine, have to wiggle the gear lever a bit whilst turning the key
but the pivot forward of this seems to be quite loose - so i guess i need to try and sort this out
where is the gear lever position sensor and wiring?
i cannot see it...
since i might wire in an override switch in the wiring to fool the system into thinking the car is in P or N.
of course i would only use this override when i was sure the gear lever was in P or N
i cannot see it...
