antbainerz
- Jan 30, 2017
I am currently having a few issues with my Automatic gearbox in my 1998 VX3.4lwb.
when setting off, pulls hard in first gear then you have to let off the accelerator for it to change up to the next gear.
when it shifts up the gearbox feels like it shifts up 2 gears so the revs are around 1k rpm. when you put your foot down hard to pick up speed, it goes back to first an bounces off the rev limiter( doesn't hold back so must go out of gear)
if you hold it half throttle it will accelerate slowly to 70mph where you have to let off again for it to drop the revs for cruising speed.
sometimes when its cold, at lower speeds you get a bit of judder.
the levels read fine on the box and it has dexron 3 in it.
Hopefully somebody can point me in the right direction
thanks for taking the time to read this
