Very basic question, but I can't figure out which is the (manual) gearbox oil fill plug and which is drain plug... anyone able to post me a pic please?
Well without pics, the drain plug is at the bottom as you'd expect, but the fill plug is a little less obvious but is halfway up on the passenger side (of a RH drive 80) They're both thin flat 24mm heads.
I can only imagine the confusion is caused by the transfer box and gearbox which might appear as one big unit if you didn't know different so 4 plugs and two different oils .
The green circled one is where you can fit a switch where it will indicate when 5th gear is in use. Towing in 5th isn't recommended just keep it in 4th when doing so as it's direct drive from the input shaft. 5th gear is a lot weaker. Same on the R series gearbox.
I find the oil takes time to drain through the centre vertical plate to reach the far side of the gearbox on filling. Best to make sure the whole lot is measured out before filling to make sure it all goes in without a false full appearance.
