SimonD
- Mar 15, 2010
I've removed the rear seats of our truck in readiness to add two leisure batteries in parallel on the rear seat floor in the middle. The associated electrics (CTEK) will be mounted on the rear cargo cage above this. I'll be adding two AGM batteries here but wanted to ask if anyone can recommend and battery trays that may already be in the market that may suit this kind of purpose? They will sit inside some ply shelves.
Although using AGM, I want to ensure the enclosure is well vented and has plastic/rubber protection for the base of the truck, on the off chance I need to replace an AGM with a lead-acid and it leaks.
