knicko
- Dec 23, 2012
Have just overhauled front and rear brakes and having removed the calipers, I have let the master cylinder drain. The colour of the brake fluid at the caliper ends was black and grotty, so good opportunity to drain it off.
Now that I have refitted everything, I am conscious that the bleeding will take a bit more work.
I know about bleeding the load sensing valve unit as well as all four calipers, but will I need to also bleed the MC and perhaps the ABS unit too? If so, do I just bleed from the unions that are at the highest point on these two units, or is there a particular way that they need to be bled?
