Hello all I think this is my first post and need advice .. I had the misfortune last year of air getting into ABS pump when replacing a corroded brake pipe on a Ford Galaxy Mk1, despite using VCDS to actuate the motors/servos inside the pump to bleed them I ended up scrapping the car though it wasn't worth much. I have as a result lost a bit of confidence with brake hydraulics on my VX80 + 150k miles (New discs and pads have left pedal response feel like there is air in the system even though have bled the corners extensively and clear and driven 200miles to bed in the pads want to treat my 80 to a brake overhaul as I frequently tow a twin axel caravan - sorry lol!)
I have a few concerns now if anyone can help please;
I am worried about bleeding the system and the effect on the ABS pump if I replace the brake master cylinder and the whole system needing to be bled, will ABS pump get air in it and be unbleedable? or if needed disconnect one or both batteries (reluctant)
What is the biggest pitfall of using a seal kit versus new or remanufactured calipers, do you flush the caliper fluid-ways in case of grit ingress?
looking at the trend of other owners are doing;
Bigg Red for seal kit seems popular
Roughtrax for Calipers but a massive £500 for a full set though there are other suppliers
grateful for help
thanks
grateful for help
thanks
