Hello!
I entered into the world of LC ownership in August.
Having browsed various forums it always struck me that many people are obsessed with boot builds - well, it rubbed off on me. I'd never done a 'boot build' before and so figured Id jump in and have a go.
There was no actual purpose, so dont ask me if I am going across morocco any time soon.
What the pictures don't show is that the floor is designed to be level when the rear seats are folded over. There is an inflatable double mattress stored in one of the boxes which runs off the power outlet at the rear. It fits the back perfectly.
I just decided I'd achieve the following : Bed / Shower / Power / Heat - all within the car. Again, no ides why - it was just 'something to do'!
Here goes:
I started with a Land Rover roof rack!
Its strange where you draw your inspiration from!
and somehow ended up with the beginning of some framework
Id already decided upon heater, power and tank/pump etc etc at this point....
Trial fitting the Fiamma 70l water tank.....to work out heights and space available
Unfortunately my phone died so this next picture is after a 3 week gap due to flu, and having made a bit of progress inbetween.
The fascia framework is in, as is the eberspacher heater.
I amrunning a 75aH battery from a T-Max split charge system. There is a switch panel built now into the side panel taking a power feed from the battery. This has a switch for the water pump and auxillery power outlet. There are two spare switches at present.
Shurflo 20psi pump is plenty to feed the ecotemp 'combi' style water heater.
working out the water filler
Fiamma water filler installed in rear quarter panel
The eberspacher - you can see the exhaust routing
Plumbed into the fuel tank;
and the outlet (exhaust) on the drivers side in the rear quarter panel.
Its about now in the build you start to panic if you are ever going to have your car looking neat ever again!
Its not finished yet - there are designs on an external ladder, also; The ecotemp needs setting up with a gas bottle and the mount for the ecotemp will be on the ladder.
Im also considering designing an awning for the rear.
Anyway, I did say I was crapping myself about how 'neat' it would all end up.
Well, I'm quite happy with it
This is the vehicle:
Interior mods include Subaru front seats, Kenwood sound system and in dash DIN size CB with two aerials (switchable) one for laning (small) and one S5000 for very long range.
I've also fitted a side exit exhaust, and a few other bits'n'bobs. Hope you have enjoyed this!
Here goes:
