Box section sills
Rob-o
Just thought I'd show how my rusty sills have been repaired, 50x100mm box and some sliders to stand on when sorting out the roof tent. Also sorted all the rust in the rear arches and boot corners, it's much quieter to drive now!
Gav missin
That's exactly what I'm planning with mine. There battered to f***. Any more pics of underneath. Was the B pillar aquard to cut and weld around. Cheers Rob
Lorin
Rob, did you do the work yourself or have it done? It is something I would like doing.
Tractionman
Saw you out and about on your home turf around Bennet Road last week Lorin.
Rob-o
The box is notched around it, I'm not sure I've got a picture of that but it wasn't technical, just fiddly. I'll try and post some more pictures. And I'll take some from underneath tomorrow.
Rob-o
I had it done. I've done the finishing touches though. If it were just the sills I might have tried but the amount of rot around the rear arches was beyond my skill level!
Rob-o
Sorry for the delay, haven't go the best pictures but they might show what's going on, basically the sill is cut off above the bottom crease, folded to 90 degrees then the box section is sat on to and welded. Then drain holes drilled through that folded section of inner sill.
