Brake problem
Kinda sounds like a master brake cylinder problem!
Hope not as can be expensive - happened on mine.
Lal
-----Original Message-----
From: [Email address removed] [mailto:[Email address removed]]On
Behalf Of Peter Browning
Sent: Saturday, May 07, 2005 3:33 PM
To: [Email address removed]
Subject: [ELCO] Brake problem
Changed all the brake pads on the 80 today, took it for a test run and the
brake pedal goes straight to the floor! There is braking but not much, and
there is back pressure on the pedal, but it still goes to the floor.
Now, I didn't disconnect any hoses, there are no leaks that I can see and
the brakes were working perfectly before I changed the pads. So why does it
now seem that there is a huge amount of air in the system?
I shall get an ezibleed tomorrow and flush the fluid through as it looks a
bit dark anyway but I'm just intrigued as to why it happened.
Any thoughts?
Pete
1995 FZJ80
-- European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
I would have a good check round to make sure you haven't damaged
anything as well - especially piston seals when you pushed them back in
- but would've thought you'd see a leak.
Ian.
> the brake pedal goes straight to the floor! There is braking but not
> much, and there is back pressure on the pedal, but it still goes to
> the floor.
> and the brakes were working perfectly before I changed the pads. So
> why does it now seem that there is a huge amount of air in the system?
> looks a bit dark anyway but I'm just intrigued as to why it happened.
> Any thoughts?
> Pete
> 1995 FZJ80
I've had that a couple of times after a pad change, goes away after a
little use, hope it's that simple for you.
Best regards,
Jon.
On Behalf Of Peter Browning
Sent: 07 May 2005 22:33
much, and there is back pressure on the pedal, but it still goes to the
floor.
and the brakes were working perfectly before I changed the pads. So why
Any thoughts?
Pete
1995 FZJ80
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=windows-1252"
http-equiv="Content-Type">
</head>
<body bgcolor="#ffffff" text="#000066">
DOT 5.1, not DOT 5
Pete
Dave Harris wrote:
<blockquote cite="[email protected]" type="cite">
<meta http-equiv="Content-Type" content="text/html; ">
<meta content="IncrediMail 1.0" name="GENERATOR">
<table id="INCREDIMAINTABLE" border="0" cellpadding="2"
cellspacing="0" width="100%">
<tbody>
<tr>
<td id="INCREDITEXTREGION"
style="padding: 0px; font-size: 12pt; cursor: auto;" valign="top"
width="100%">
<div>You should not mix dot 4 and dot 5 in the same system.You
will be very lucky if you have not killed all the seals in your entire
brake system.</div>
<div>If you can flush it out with dot 4 now.</div>
<div>Sorry to be the bearer of bad tidings..</div>
<div>?</div>
<div>?</div>
<div>Dave Harris
97 VX 1HDFT Devon UK
OME Springs and LTR Shocks</div>
</td>
</tr>
<tr>
<td id="INCREDIFOOTER" width="100%">
<table cellpadding="0" cellspacing="0" width="100%">
<tbody>
<tr>
<td width="100%">
</td>
<td id="INCREDISOUND" align="middle" valign="bottom">
</td>
<td id="INCREDIANIM" align="middle" valign="bottom">
</td>
</tr>
</tbody>
</table>
</td>
</tr>
</tbody>
</table>
<span id="IncrediStamp"><span ltr=""> </span></span>
<pre wrap="">
<hr size="4" width="90%">
Checked by AVG Anti-Virus.
Version: 7.0.308 / Virus Database: 266.11.6 - Release Date: 06/05/05
</pre>
</blockquote>
</body>
</html>
