Hi Guys
Been doing a bit of research into brakes and such and would like to know a few things if possible.
Most of the info I looked at is very conflicting to say the least.
Do drilled and slotted discs really make a difference in the braking ability of the discs to provide that extra stopping power.
Do teflon brake pipes make a difference aswelll.
What is the actual difference in the disc diameter or the contact surface between the early 92 and the late August 92 80 series.
Presuming of course the change of caliper is made and the rims are 16" instead of the 15".
Has anybody tried these drilled and slotted brake discs.
Does synthetic brake fluid make any difference.
How do you adjust the rear brake sensor.
I ask all these questions because I now know I am looking at a complete front axle strip down because of the crap work Toyota put into doing the job in the first place.
I cant do it physically but can mentally, the cruiser is grounded and I have to find a guy who will do it, so maybe I need to assertane if he knows his stuff to start with.
Happy Holidays
John 92HDJ 80 1HDT.
Happy Holidays
John 92HDJ 80 1HDT.
