OK, found the pictures but clicking 'manage attachments' brings up the wait icon for ages so here is the lowdown.
Looking from the rear of the car and on the top (obviously), and at the rear of the transfer box above the cover plate with five bolts is a 90 degree connection, this is pushed into the casing and IIRC 8mm pipe is connected to it. This goes forward a few inches and then come to a 'T', the 'T has two 8mm ports and one 6mm. The 6 mm runs across the top of the transfer and meets with the 6mm nipple on the centre diff lock. The 'T' then continues along the left hand side of the gearbox and connect to a 'Y', the base of the 'Y' is a push fit into the top of the gear stick housing, the remaining connection from the 'Y' continuing up the side of the bell housing and is held there by a bracket that goes to one of the top bell housing bolts, hope that helps?
regards
Dave
