Brown dashboard trim pieces and kick panels
Eurasiaoverland
brunei
I have a general market RHD 1989 BJ60 with brown (sepia) trim, and I'm looking for the following pieces of dashboard trim:
-Fuse box cover (88-90)
-Fascia surrounding the heater controls / clock (88-90)
-Both kick panels
-Round blanking plug below where the H4 / 4WD switch is.
Only interested in undamaged pieces please.
I'm also after various air conditioning paraphernalia for an 88-90 RHD HJ60/61 but as I understand the UK 60s did not get air conditioning as an option. Please let me know if you gave something (knackered compressor, high side hoses, evaporator box etc).
To be posted to Kent, UK
EO
Hi Is this one of the bits you r looking. For I might have more if I can find them .
Hi Tony, thanks for the pictures. That's definitely the piece I'm after, but there are two colours and I can't quite tell which one that is.
One colour is like milk chocolate, the other a kind of tan or butterscotch colour. I'm after the chocolate colour please.
I'm also after the small plastic blank in the dashboard which covers the hole where a choke would be in an FJ. It's the hole below the rectangular switch which puts the transfer in 4WD on the vacuum type transfer case. The picture is if my dashboard which has been drilled out a bit, so the hole should be a bit smaller. I think the piece would be black, maybe brown.
I'm also looking for the surround for the heater control unit, though this is specific to facelift 1988+ models with double square headlights.
Other brown bits I want are keeping kick panels, a straight glovebox door, A pillar trim pieces and a press button type drivers seatbelt.
Thanks!
Daniel
Hi Tony. I've just done a bit more research and realise that the colour of your bit there won't be the right one. From the Fuse diagram I see it's from a pre 88 model and I now realise my colour was only used from 1988 on.
I'll amend my original listing! Sorry about that.
Hi Is this any good
Hi Tony
Again, thanks but the same problem - the bits are from a pre 88 model (certainly the heated rear window switch is) so the switch size and trim colour will not match.
It's hard to tell from the pictures but is that more of a beige or a chocolate brown?
