As for aerial, there are so many choices we could be here next week. It depends on what you want. Fixed, semi-fixed or mag-mount. The latter being the easiest option if you don't want it on all the time.
Fixed: No worrying about removing it. gets broken off by "lads" walking on the streets (Ask Paul)
Semi: You have a mount either mounted to the bull-bar / roof rack etc and clip in the whip part when you want to use it.
mag-mount: One very strong magnet and put it on when you want to use it.
The advantage of the mag-mount is you can move it. On a number of lanes with low branches, it sounds like an angry pianist on your roof. Gets comical with the sounds it creates. You can stick it on the bonnet which then saves you height.
Don't get a shorty aerial if you can. They have don't work as well as a 1/4 wave (which is 1.8m long). They do work, just at the extremities, the quarter wave whip will still work over most loaded ones.
If you can, mount the aerial in the middle of the "base". Base being, bonnet or roof. Mounting it to one side creates an uneven ground-plane (the roof) and your signal / SWR will suffer slightly. Again, when mine starts getting crackly, you'll be deaf. In a convoy, you won't notice a difference. When mounted off centre to the ground plane, your radiation lobe is distorted.
If you have a bad ground-plane, (no roof / bonnet etc) you'll struggle to get a good SWR, have a limited range as well as struggle to hear others from a distance.
SWR:
To test your SWR, mount the aerial in the desired place. Drive to an open space. By open, I mean, don't do it in your garage or parked next to your house. Move away from it.
* All (most) the aerials should have a grub screw in the base for adjusting the whip. Loosen it, find the mid point of the available play and tighten it slightly.
* Turn to channel 20 on the CB (mid point)
* Ensure the SWR meter is connected correctly (should be labeled)
* There should be a switch marked FWD / REF. Move to FWD
* Key your mike (transmit) and adjust the turning knob until the needle swings all the way over the the "set" mark on the dial. Should be on the right.
* Stop keying
* Change switch to REF
* Key mike again. needle should stay below 2. if it's in the red, stop keying! You'll break your CB.
* Adjust the aerial a mm or two up.
* Repeat above. if it gets better, keep going until it gets worse. if it gets worse, go the other way (shorten aerial)
Once done, tighten grub screw.
A bad SWR does 3 things: Poor reception, poor transmission and worst case, will pop your transmitter.
I'm sure someone else will come and add to it...
