- May 12, 2020
Hello, I'm mike.
I have looked a fair bit at threads for this subject but I can't find any that don't have a light come up on th dash at all.
My amazon centre diff lock, and rear diff lock don't work, rear one just flashes, I'm guessing will be the usaul Toyota seized actuator, but its the centre one that I want to fix first.
So bit of info, I have no centre diff lock light on the dash. Not even when you first put ignition on, when the rear one pops up and goes of, there is no centre diff lock one.
So I swapped the bulbs in the dash to check it hadn't popped, still nothing.
Check the fuses in the nearside front under the black cover in the kick panel, all ok, I have one marked diff? Is that the centre or the rear one? I got told one marked gauge? Or somthing is another one to do with the difflock, I'm pretty sure I checked them all and none where blown, but il re Check to be sure.
I took the switch apart to look at the circuit board solder joints appear ok, not dry, wiring apppears ok to the switch in the dash.
You push the centre diff lock button and nothing happens, no lights, no noise, no relays click, nothing. Tried it in high and low range.
Also there is nothing that comes up on th dash to show it's in low range, only the abs light comes I guess as it gets tuned of in low range.
So I guess questions to start, how many fuses are there? And where are they if I haven't been looking at the right ones, and also what are good things to check to rule out, or tests to rule stuff out.
Please help guys
Best regards
Mike
Please help guys
Best regards
Mike
