You may find that after fitting Milners U/J's you cannot get a grease gun on them, even when removed from the truck.
These are sold as for a 3rd gen Surf, but I checked a couple of sources and found the U/J's were the same for the 90.
http://www.roughtrax4x4.com/?doc=16&cid=178&vid=192
The stock I received did not have the nipple on the end cap as shown, but had a screw in right angle nipple not unlike genuine, I still had to put a small washer under the nipple to set it off a small amount, but now I can grease when fitted with a standard gun
