Cold starting etc
Well I am sorry I mentioned the reliability or otherwise of diesel fired
engine heating systems. As for LR problems, then look in back issues of
LROI to start.
Off topic but relevant - on the residential boat front, as soon as drip
feed diesel heaters became available there were, and still are, droves of
blown air heater owners converting due to all the inherent problems
encountered.
But WJ.......
you will be pleased to know that I fitted a Dutch made Kabola boiler
(originally made for trawlers) to my boat and many have admired it and
fitted the same. But at 6KW output its a tad too high for heating my 80
engine. I'll look further for others that heat the coolant via an electric
element on a timeswitch.
I will now crawl back under my lurking stone ;o)
But should I use low sulphur diesel in my 80 or not bother ? No one
appears to have an answer !
Jon
'92 HZJ80 ex UN surplus in Bosnia - 42 degs today and the 80 started quite
well :o)))
On 6 Jul 2004 at 21:37, toy80 wrote:
5-6kW is what both Webasto & Eberspaecher deliver....:))
(there is also a Japanese brand Mikuni, but haven't found much spec's
about these thusfar)
And I once bought a 12kW Webasto coolant heater, out of a military
command-post container....still looking for the appropriate vehicle
to fit it....either an Unimog, Pinzgauer, Duro or Volvo TGB
6x6....;))
Think different, think gas-to-liquid diesel....;))
http://www.google.com/search?hl=en&ie=UTF-8&q=gtl+diesel+shell+toyota
Bye,
Willem-Jan Markerink
The desire to understand
is sometimes far less intelligent than
the inability to understand
<[Email address removed]>
[note: 'a-one' & 'en-el'!]
