RL12
- Mar 25, 2012
Hi all,
For a few months I've had a intermittent oil temp warning light that comes on after 5mins for a few seconds. The engine tempts normal so put it down to dodgy sensor.
Most recently The front heater matrix doesn't seem to get warm anymore and now more worryingly after starting up the car it cuts out after 10seconds and needs a fair bit of cranking and throttle before it starts again.
I'm planning on changing the coolant but am a bit worried that it's more terminal than that if the starting problem isn't related to it?
Also is it pink coolant or blue coolant?
Thanks in advance, I know you're a knowledgeable bunch!
