goodoldboy
- Apr 30, 2010
I'm looking for a remote alarm/central locking fob for my 95 .or any info on repair gratefully received
It would be a scouser fixing alarm fobs the battery is good but ill take a look at the buttons.the other fob works as it should so no other probs.I sent both mine to a guy from Liverpool i found on ebay and i think i paid more for tracked delivery than i did to have the keys sent back in perfect working order , sadly he wasn't on there the last time i looked .
Changing the battery is easily done but the fella in Timpsons tells me not to leave the battery out too long as they might not have an infinite memory ?
I was having trouble again after a couple of years and decided i needed new rubber for the buttons but couldn't find any so i used a paper punch to cut out some plastic to reinforce the contacted area between button and board (the true button is on the board) . Milk bottle plastic or something similar will do and i stuck it in with silicone glue . My first attempt failed because i used too much glue .
Another time i had key problems turned out to be because i had bent the bracket that holds the security button under the bonnet and it took me a while to find the fault because it was intermittent .
splendid , thanks ChrisYou can leave the battery out as long as you like. It doesn't forget its code. But you might need to press both buttons simultaneously to re-associate it with the car.
Is it one of these?
http://www.ebay.co.uk/itm/TOYOTA-RE...097973?hash=item4b1291e335:g:3zkAAOSwLnBX6ndR
Another here. In fact there's several on there at the moment.
http://www.ebay.co.uk/itm/toyota-la...227666?hash=item2a83a49492:g:EzEAAOSw~1FUW5kz
There's a reprogramming thread on here somewhere....Button on the box ?
Yes press the buttons simultaneously if your bag is on the lower peg after Latin.but if you have P.E. before Latin...
On the collie there should be a box in the dash usually
There's a reset button on it
You press that and it allows additional fobs to receive the code.
