Well guys as some of you know I have just come back from France where I suffered a slight over heating problem. Nothing that I could not keep under control but needed looking at. Whilst in France Jon Wildsmith and I took a look at the old girl and found that the condesor fins were knackerd and it would benefit fitting a new one. Jon also put forward a suggestion that as mine has been lifted and that I have full under body protection the negative air presure that is usually there has been interupted and the hot air is not being drawn away from the engine. Thus the air is heated then re heated and just gets hotter and hotter,solution to this is a scoop in the bonnet with a Kenlow fan.
Under Jon's wise advice I decided to tackle the problem by trying to fix the problem without the need for the scoop and fan, only resorting to that as a back up for when I am in a very hot climate. It looks like it worked all I needed was a new condensor, radiatior and fresh Mr T. coolant.
Changing the radiator and condensor is a straight forward job. The radiator comes out first.
Firstly undo the 4 10mm bolts that hold the fan cowling to the radiator and just push it back over the fan. You do not need to get it out as there will be enough room with it just pushed back.
Remove the grill, top and bottom hoses and the two transmission oil pipes at the bottom (if its auto). Undo the 4 bolts around the edge from the front, You can remove the bolts completely as the radiator is hung on hooks that hold it in place. The bottom two can be reached using a long extension bar through the bumper.
Next the condensor, release the pressure from the system then undo the two pipes, one top left front and one bottom right front. If you have a winch mount like mine then the bottom pipe is a bit of a work up but no major hassel. The condensor is more or les susspended on rubber and there are only 2 bolts to remove at the top front. Undo these and rotate the bracket round, push the condensor back and lift out.
This is what I found when I removed mine and I think that you will agree that my overheating problem was something to do with this. Firstly the condensor.
Now for the radiator.
The new ones are now fitted and all seems fine, all I need to do is find a hot day and a mountain to climb. That sounds like an excuse to go back to France
All thats left now is to fit the precationary fan and scoop into the bonnet just in case I go to the desert some time soon.
Steve
Steve
