• The technical difficulties should be resolved. If you're still having them, please contact us via email on admin at this domain.
Cruise Control 70 MPH limit
Hi All
I've notice that my Jap import Cruiser has a 70 MPH cruise control
limit.
I.e you can't engage cruise above 70 MPH. Is there a mod for this ?
Rob
My UK spec 80 could only manage 80 on cruise control
Alistair
Ex -'97 HDJ80 manual
-----Original Message-----
[mailto:[Email address removed]]On Behalf Of Rob Edwards
Sent: 16 November 2004 22:20
To: [Email address removed]
Subject: [ELCO] Cruise Control 70 MPH limit
Hi All
limit.
Rob
Hi Christopher,
Thanks for the info. I've just got to find where the
Control module is situated.
Rob
91 Jap import
TLC 80
UK, Portsmouth.
On Behalf Of Christopher Bell
Sent: 17 November 2004 09:27
Subject: Re: [ELCO] Cruise Control 70 MPH limit
Rob
Did this
(http://www.birfield.com/archives/html/80scool/2003-06/msg00005.html)
not do any good?
Christopher Bell
Rob
Sorry, can't help you there. My Haynes manual concludes "... if it isn't [working] take it to a dealer service department ..." without explaining where the wretched control module is. And the wiring diagrams in the back are useless.
However there must be a solution since my (UK spec) cruise control definitely holds speeds above 70mph.
Christopher Bell
Hi Rob,
I did a search of various archives, but couldn't find anything
definitive other than what Chris has found which he has already
provided to your previous posts on the 80s list.
Logically, I would try to find which ECU is used to control it and then
see if it is interchangeable with the ECU in a UK spec model that
doesn't have the restrictions.
Mobile: 07971 540362
Search the old Aussie 80scool or post a msg to the new board (lcool_aus ?).
I'm sure someone has fixed in the past down under (maybe an import there
too?)
Lal
Sent: Tuesday, November 16, 2004 3:20 PM
Hi All
limit.
Rob
