Cruise control issue
I had to go to Bristol last night and the cruise control initially
worked for a minute or so on the flat, but going up a hill at 70 mph it
suddenly dropped out, the green "cruise" light flashed 4 times and then
went out completely, and thereafter it refused to work at all: no light,
no nothing.
After an intermediate stop in Taunton at which the ignition was turned
off the "cruise" light came back on again when requested, but the system
dropped out immediately with flashes as before when I tried to use it.
On the way back from Bristol it all worked fine.
I've checked both fuses and for any obvious mechanical damage, and it
all looks fine to me, so I'm hypothesising that maybe it was the cold
which stopped it working initially, and the run up the motorway was
enough to thaw it all out. Perhaps the cable got a bit iced up and
asked too much torque of the system or something.
Has anyone any experience of this, or any advice to offer? For example
should I be lubricating cables, and if so - how?
Sorry, I realise this is a bit less mission-critical and exciting than
new diffs and gearboxes, but all thoughts gratefully received!
Christopher Bell
Devon, UK
1996 1HD-FT
Jon
Thanks, I'd forgotten about those. I've downloaded the first two so I'll
take a look... pages BE 103 - 126 seem relevant.
I *think* it was four flashes, but at 70mph on the motorway one can't
really stop to look! Perhaps it was 5. I'll do some stationary
diagnostics and see what it has to say for itself.
| Hi Christopher,
| RM184E has a short section on the cruise control and how to get the
error
| code. RM315E has a bit more. Those are both on mudtoys (links in
previous
| emails).
| RM434E has a couple of pages and RM534E has 55 pages on the cruise
| control! If the problem returns so that you can diagnose it i'll scan
| those because now I've looked at it there is all sorts of interesting
| information about other things like the imoboliser that seems to crop
up
| from time to time.
| I'd do a dummy run on getting an error code and wait for it to happen
| again.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<Jeremy wrote>
| Cruise control is much more useful than it used to be with all the
road
| works and average speed checks...
Too true! I use it as a matter of course now in those.
Incidentally having read through the diagnostic check list the very
first entry was "excessive clutch or motor current", which pretty much
points to the "frozen up requiring too much torque" scenario.
I think I'll do a bit of cleaning followed by oil and grease squirting
and hope it stays OK.
CB
This happens me all the time when in cruise control going up a long
steep hill - the cruise control can't catch up with the power required
to get me up the hill.
I've never tried fix it - just assumed it was a nuiance of the cruise
control in a cruiser.
On the subject of cruise control - I don't use mine any more because
I'm convinced continued use of it buggers up the drive train - UJ's
and the like. When you hit the brake when in cruise the drive train
takes an awful wallop. It's OK once and a while but when on a long
trip the wallops add up.
As technical as ever
Niall
On Thu, Jan 8, 2009 at 9:54 AM, Christopher Bell
Niall,
From where does this wallop come from?, the first thing that happens
when you brake with CC on is that CC dissengages. Any torque you feel is
caused by the fact that you do not have your foot on the accelerator to keep
up the engine speed, so you feel the car going in to normal engine braking.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Niall
If your speed drops more than 5mph below the set speed then it is
designed to disengage, so I think you need more power or less ambition!
In my case it didn't just disengage but actually turned itself
completely off and refused to come back on again until the ignition had
been cycled off/on.
You are right about the shunts to the drive-train during rapid
disengagement, and I try to avoid that. When I'm going up steep hills
on cruise I tend to floor the accelerator - partly to give it the best
chance of maintaining speed, and partly to avoid that shunt if it does
decide to disengage.
BTW I found that the slop in my drive-line was *hugely* reduced when I
replaced the front CV joints, it made a really remarkable difference.
CB
<Clive wrote>
when
| you brake with CC on is that CC disengages. Any torque you feel is
caused
up
braking.
Clive
If you hit the brakes or clutch the CC disengages immediately, and the
effect is identical to lifting your foot rapidly off a well depressed
accelerator. On mine this gives a real shunt through the transmission,
although I suspect that my manual box will accentuate this more than an
auto one would.
To drive mine smoothly, cruise control or no, you need to lift off the
accelerator in a smooth fashion.
CB
glad this was brought up im in argentina in mid summer so its not a climate related problem...mine somertimes works perfectly other times get the fllashes then i goes off...ive tried to rep[licate what happens but cant!!! im on the way back to uk by cargo ship so ill have to wait for one of yu bright boys to solve the problem
regards
jeffv watts> Subject: RE: [ELCO] Cruise control issue> Date: Thu=2C 8 Jan 2009 16:32:25 +0000> From: [Email address removed]> To: [Email address removed]> > Niall> > | > | This happens me all the time when in cruise control going up a long> | steep hill - the cruise control can't catch up with the power required> | to get me up the hill.> | > | I've never tried fix it - just assumed it was a nuiance of the cruise> | control in a cruiser.> | > > If your speed drops more than 5mph below the set speed then it is> designed to disengage=2C so I think you need more power or less ambition! > In my case it didn't just disengage but actually turned itself> completely off and refused to come back on again until the ignition had> been cycled off/on.> > You are right about the shunts to the drive-train during rapid> disengagement=2C and I try to avoid that. When I'm going up steep hills> on cruise I tend to floor the accelerator - partly to give it the best> chance of maintaining speed=2C and partly to avoid that shunt if it does> decide to disengage. > > BTW I found that the slop in my drive-line was *hugely* reduced when I> replaced the front CV joints=2C it made a really remarkable difference.> > CB> ____________________________________________________________> Electronic mail messages entering and leaving Arup business> systems are scanned for acceptability of content and viruses> > --> European Land Cruiser Owners Mailing List> Further Info: http://www.landcruisers.info/lists/
Are you a PC?=A0 Upload your PC story and show the world
http://clk.atdmt.com/UKM/go/122465942/direct/01/
