dash lights up like a christmas tree?
Des johnston
11
0
6
all the dash lights are on in my 1987 70 series. i have changed the altenator and regulator still no luck!
any body no what else i could do :?: help would be greatly apreciated!
regards des
Rob
3,019
16
38
Bristol
have you checked if the alternator has a good earth? I have heard that this is a common problem, but seeing as you have changed the alternator then you may have covered this
Steve H
I am in uk
May 22, 2010
233
34
28
Hamble, Southampton
Try earthing the dash if its the earlier metal one. I remember reading somewhere that the dash on some 70 series is earthed to run all the lights, etc. Run a temp wire from the battery earth point to check it out.
AdBlock Detected
