Dashboard issue
mohsenawies
mali
Dashboard issue not working it is ground problem i think any help please
p
The car is a 2015 model from the fleet that I received and the entire instrument panel does not work and there is no time reference for its maintenance. Please help from where to start ?
Fleet? If you have access to another similar truck, put your cluster in it and see if it works. If so, its likely a wiring problem in your truck, else the cluster needs repairing.
In fact cluster was tested in another vehicle and it works well and the problem is actually in the fuse or the problem of wiring, especially the ground
So when you check the ground wire in the cluster connector, it has no continuity to body ground?
Exactly what tests have you done so far to conclude that the ground is the issue?
We probably need all the information to try and help properly!
