Steve H
- May 22, 2010
Hi. I have just fitted a lithium battery in my caravan hooked up to a 100watt solar panel with an MPPT solar controller. I want to fit a DC/DC charger. Does this need to go in the caravan or should I fit it in the truck? I was thinking of using Anderson connectors to supply the charger along with 10mm2 wiring to supply a 20 amp feed and so I don't have to touch any of the vans original wiring as its still under warranty. This weekend we went away and just used the switch relay to charge the battery and it coped OK but don't want to risk any problems either with the battery or alternator. The solar panel is permanently connected to the battery to maintain charge when in use or in storage.
I have fitted a Victron MPPT 75/15 controller and a Victron Smart Battery sense. All weekend the battery voltage didnt drop below 13volts . Also do I need some sort of battery monitor to check SOC? The Victron app is quite useful for this but not sure if I need anything else to make sure everything is working as it should.
What do you think? Any advise or suggestions welcomed.
